On my prevoius I said that my car went on limp mode due to the fault code 13 which is shift control unit ( only for AT) after I installed EBC
I have done a lot of reading about this and I have check any other possible causes, engine coolant sensor, throttle control sensor, maf sensor, all fuses, and resetting the ECU but did not resolve the issue, ABS/TCS/Slip lamp still remained on and I cant get pass 3rd gear and 2500 RPM, also I will try replacing all hoses to make sure that there is no leaking anywhere what so ever as that all i know other than doing a full test which I am not capable of performing such test.
I am all out of ideas and I am not ready to spend money to have the car fully inspected and diagnose and I do not want to be told by the mechanic of what I already know and pay them for telling. Any ideas of what can possible cause this? area where I can check my self and not too difficult
Should be worth it to have someone look into the problem (gear lever,gearbox,shift control unit circuit) and have it fix, or just do a manual conversion. Please don't give a 1 sided answer, really do want to hear you guys opinion and if the only answer is the manual conversion I would like some help collecting parts and at reasonable price ( Local preferred)
link to what parts I be needing http://www.sau.com.au/forums/topic/1...ing-r33-parts/
thanks
thanks
