Well.. So far the dwell spikes haven't resurfaced since the replacement ViPEC was installed. That's good.
However, there is still a hot starting issue. The car will start fine if it is cold, but if you shut it off and attempt to restart while it is warm. It refuses to fire.
They are rebuilding the wiring harness again.. if that doesn't do it. Rewiring the whole car may be next. It'll be next week before I find out if that solved the problem if they must go that route.
At least some progress is coming along.. however I am almost sure the last gremlin is hiding, and will only appear after I am driving it on my own. As it always has! :roll:
