wow they are also alot more expensive than expected.
Project : super sexy wangan slut.
and thats before shipping... FROM AUSTRALIA! lolOriginally posted by cschepp View Postwow they are also alot more expensive than expected.
luckily i got mine from a member.
pre shabbat update//
Crystal Castles are from toronto}therefore are great.
have my battery relocation all setup ( taylor box and a Painless Performance remote disconnect kits)
will clean up the install a bit more but its basically how its gonna be , cable is mated with the wiring harness from the rear divider wall to the firewall .
Removed fender to install the kill unit,
(red coming from battery , black runs to the starter , fuse[bottom left] and then one wire running into the cabin for the switch its self.)
measured out and cut the first set of lines for my relocation / twin oil cooler set up.
ps. i r winnars
thats in even worse shape than my timing gear. howd you get it off?
ps- the random black lady in the background of the music video was thinking exactly what i was. "wtf is this crap?"I've been brushing my teeth with jack but it's resulted in terrible amounts of tooth decay.
alot of grease , a hammer and 2 pry bars ( the broken part was from me initially trying to drill into it to use a pully puller ..didnt quite work out lol)Originally posted by m_melen View Postthats in even worse shape than my timing gear. howd you get it off?
Ok so this is over due but heres my SUnday update.
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Had a crazy sunny sunday this week , nicest day of the year by far
ex:
k so im changing that flaccid maf - turbine pipe to a nice aluminum one vvvvv
WIckedness i know,
But i had to eliminated the vacuum fitting on my Plenum which meant i didnt have a vacuum source for my catch can so i opted to modify the new aluminum pipe .
i first need a nipple.
Found one!
SNIP SNIP
GOt it fitted in nice ans snug , then spray bombed it a nice gloss black
i got the angle grinder out and cut out a hole in the rebar for my FMIC .
and i blacked it out as well as the top and sides of the head lights.
more to come jsut gotta upload pictures.
BTW , this is what it looked liek 24h later
T_TLast edited by RABBIT; 03-25-2011, 12:18 AM.
I know im in newmarket and one day its all nice snows melting i get to skate, than bam next day when i wake up in the morning all i see is a foot of snow for me to shovel -_- Hate canadas un-predictable weather.Originally posted by RABBIT View Post
updates / 1800 post .
my oil filter relocation / cooler set up
-1 Grex relocation kit
-1 Trust oil cooler
- 1 ARC "grill" style oil cooler
i got the ARC oil cooler from yahoo auctions ( big ups to Adam at Feast)
its probably my favorite part ive ever bought just cause its so cool and is gonna make my front end look so mean .
came silver and cracked and chipped so i spray boomed it black with a nice clear coat
sicknessLast edited by RABBIT; 03-25-2011, 12:21 AM.
I vote yes to the black 930 Turbo.Originally posted by RABBIT View Postgot a GTR gauge cluster off Bignate , and put some nice super bright LED's in her :
out with the old ...
in with the new..
Before :
After:
YAY 10k red line! ( dont mine the shitty camera )
135
hey so cars almost done , im not going to any more major updates till it is road capable.
im taking it to an awesome shop in Toronto called Dyna ( http://www.dynamotorsports.ca/)
their gonna make my intercooler piping and do my oil pump.
i still need to buy:
-Alt and PS belts
-water temp gauge
-2 reclineable recaros
-Wizim EBC (www.popformance.com/default.aspx)
-welded in half cage
i think thats it ,
im looking at getting new daily tyre's anyone got any suggestions?
oh and does anyone know of a company that makes front under diffuser/panel? or even a skid plate?
^^ thanks, ill check em out.
who needs a water temp gauge? just pull over when you hear a boom and see smoke pouring out of your hood. that's an accurate way to tell when your car is too hot.I've been brushing my teeth with jack but it's resulted in terrible amounts of tooth decay.
play through the pain ? lol ur such an americanOriginally posted by m_melen View Postwho needs a water temp gauge? just pull over when you hear a boom and see smoke pouring out of your hood. that's an accurate way to tell when your car is too hot.
