Project: GTS-ST (twincharged R32)
    Originally posted by Brody_Howell View Post
    it was in a D SPORT magazine a bought, they also did it to an r35 GTR.. pretty effing badass. GTR had 4 methods of forced induction hhahah
    actually 2 methods: Turbocharging and supercharging. but there was 2 of each, so 4 components making boost.
    1966 Pontiac Beaumont | 1972 Nissan Skyline 2000GT-X | 1990 Nissan Skyline GTS-T Type-M
    1991 Toyota Celsior C-Type Supercharged | 1991 Toyota Cressida | 2008 GMC Acadia
      haha thats what i meant though, 4 methods of making boost. I'm guessing you've checked out Power Enterprise's stuff?
      White 1990 Nissan Skyline HCR32.
      "Skyline" Is a lifestyle.
        yeppers
          Originally posted by christdeyoung View Post
          A buddy of mine has an STI with 800HP with sequential turbo's AND a clutch drive supercharger. He wants me to try a twin charge setup on my GTR....and I believe I want to do so.
          This supercharger clutch you guys are talking about...can it handle high speed engagement?
          For instance, coming out of a turn...revving 6 grand. As soon as I hit the throttle, I don't wanna wait for that GT40 to spool. Can the clutch handle the load of bringing the supercharger up to speed instantly? I'll be shooting for the 600whp mark...so I guess I'd be looking for a supercharger that would flow to around 800 CFM? Sound right?
          Race gas machine ftw! for sure not a street car
          lol
            fronts are done:
              ok, so here is the scoop on what needs to be done: (red=done) Seems to be so much when i write it all down...and i am probably missing things.
              1 Front Lower Tension Rod
              2 Front Upper Arms
              3 Front Castor Arms
              4 Front Lower Arms
              5 slotted/dimpled rotors (F)
              6 Yellow Stuff Pads (F)
              7 Rear Upper Control Arms
              8 Rear Lower Arms
              9 Rear Upper Traction Rods
              10 slotted/dimpled rotors ( R)
              11 Yellow stuff Pads ( R)
              12 HICAS lockout/removal. (rack, lines, solenoid)
              13 Rear Sway bar
              14 Roll rear Fenders
              15 Fuel Pump
              16 replace fuel line from tank
              17 FIT Body Kit
              18 FIT Front Fenders
              19 bleed brakes
              20 install Line Lock solenoid
              21 Master Cylinder brace and strut brace
              22 fab & inst front brake hard lines
              23 Brake Lines to capliper (F)
              24 Wheel Alignment
              25 complete removal of AC system
              26 Oil relocation/cooler kit
              27 Lines/fittings for thermostat
              28 180 degree thermostat
              29 install Oil pressure sender
              30 install Oil tempurature sender
              31 Stainless Coolant Bottle
              32 Coolant sensor flange
              33 coolant temp gauge
              34 FAB & INST Fan shroud
              35 Electric Fan x 2
              36 Electric Fan thermo switch
              37 Throttle Cable
              38 Intake Manifold
              39 Throttle Body
              40 FMIC
              41 Intake piping
              42 Fuel Filter
              43 Fuel Pressure Regulator
              44 Pressure Gauge
              45 Fittings and EFI hose for FPR
              46 Injectors
              47 Fuel Rail
              48 Battery relocation
              49 Spark plugs
              50 Coilpacks
              51 CF cam gear cover
              52 coil pack cover
              53 EGT
              54 Exhaust manifold
              55 Spacer
              56 Turbo
              57 Bung for wideband sensor
              58 install Wideband
              59 exhaust cutout, mod into test pipe
              60 s/c boost gauge
              61 103mm pulley
              62 Supercharger Mounting Brackets
              63 install SC-14 supercharger
              64 plumbing
              65 Piping
              66 Wiring
              67 LEDs in climate control
              68 relocate temp controls
              69 fab CF 2DIN for console
              70 ViPEC ECU
              71 fuse block
              72 run & inst all wiring
              73 reinstall all gauges
              74 Seat rails
              75 Seats
              76 LED tail lights
              77 3rd brake light
              78 install Body Kit
              79 install Front Fenders
              80 Paint
              81 CF eyebrows
              82 CF radiator cooling plate
              XX Adjustable cam gear
              XX timing belt (Greddy)
              XX Brake Lines (R)
              XX Water Pump
              XX 320 km/hr speedo
                turns out im a noob at making brake lines and only did a single flare when it should have been a double flare (to handle the pressure from the braking system without splitting the lines). i also didnt "bubble" flare the ends that go to the line lock solenoid.
                so.......back to the drawing board. i am going to salvage what i can (i.e. cut off the single flare and make it a double), but some of the shorter ones need to be re-made. good thing it wasnt too hard.
                i'll post some pics of the progress
                  what kind of power figures are you expecting??
                    ~350+ hp
                    im not building this for massive top end hp, but more for an early hp output from the supercharger while the turbo spools.
                      ~350+ hp
                      well..sounds like a great project..
                      i wish you the best of luck brutha.
                        goy my Do-Luck style body kit and wide/vented front fenders this week
                        I also got the full HICAS lockout bar with tie-rod replacements
                        Pics to come
