Allready addressed that issue don't worry. Have electric ones now. Only thing mechanical is my boost gauge but air won't kill you. Welded the front of my cage in yesterday and did some more wiring. Made some more gauge mounts and a few other things. I'll have pictures tommorow.
my build thread, gts...ish
well, went and picked up some parts, and started putting it together didnt get much as far as pics along the way but here is some now
mods ive added so far are;
-stock head gasket
-arp head studs
-oil return from the back of the head to the pan
-plazmaman intake manifold
-555cc tomei injectors with gtr resistor pack
-garret t3/t04e 60 trim turbo
-mishimoto rad
-fmic
-samco rad hoses
also ordering nistune today, can't wait!
ok cool , so need need to re route? just clip lines and plug?Originally posted by GavinJohnson View PostHey rabbit, I just capped em off with a 3/8 rubber cap. Need to clamp them too cause the coolant passage has little holes that go up to that rail across the intake. There's one right beside the t stat housing too.
and do you know where the line on the other side of the tb leads to?
