A couple weeks back I picked up an Impul Skyline (number 88 of the 200 made) at a local insurance aucton with the intent of rebuilding it. Heres what it started out as:
It either swiped or got swiped by a new dodge ram on the drivers side, pushing the vehicle into the center curb. Both front sides needed lower control arms, tension rods, and sway bar links.
Since it got hit on the drivers side, the wheel broke from the control arm, and smashed into the back of the firewall/inner fender bending the metal in.
New suspension parts from a 240sx:
Sitting properly again on rx7 rims with the suspension all fixed up:
I was able to find the original owner, and picked up several parts from him. Heres a picture with the oem rims back on and the bumper reattached:
The car came with a gtr cluster and impul speedo, so I bought a gtst speedo from the original owner and swapped in the impul speedo:
He also sold me a set of impul horns, and I picked up a nismo horn button that I installed:
I then had it shipped off to the shop to have the inner fender well fixed up, heres what the damage was:
I got some bad new from the shop today though that has put a halt to the project. They found more rust where the damage is, so to fix it properly I need a donor vehicle to swap over pretty much that side of the front clip and a bit of the firewall. This means big big money especially with the labor involved.
I asked them whether they could just cut out the bent and rusted section, but they said it wouldnt be the proper way because it would leave a pretty weak area.
So tonight im gonna go check out a skyline that ill either use as the donor vehicle or use as the new project and partout the impul
