Hey man that ain't no rb25 turbo u got there the stamping on the compressor housing (45v4) say it's a vg30 turbo, u didn't check the rear housing stamping did u by chance? If u did, did it say op6? Cuz if so you've got the biggest baddest factory Nissan turbo there, very nice
feyd182's GTS 4 Daily Babyzilla
Really? Guy on the forum here sold it to me as a rb25. Lol, at any rate it spools and sounds awesome. Didn't see much on the housing, but I poke around lots in there so next time I'll check. Thanks for the heads up.
Sent from my iPhone using Tapatalk1989 R32 Skyline GTR SOLD!!!!
-Bruce Lee
See if you can get a mirror back there to see some numbers. I have a little mirror with a swivelling head if u wanna borrow it.Regards,
Ken.
So far the only thing I can see is 21U E. Did this from under the car looking up at the rear of the housing. From what I found on the web, it should be a stock r33 GTST turbo. Ball bearing and apparently has a ceramic exhaust wheel.
-Bruce Lee
So apparently rb25 turbos can't handle more than 10psi. Turned up the boost on mine and blew a bearing. Pics to follow once I yank the piece of **** outta my piece of **** car.
UPDATE: Got the dam thing out of the car and low and behold, compressor side bearing has completely spun and the exhaust wheel has a chunk missing from one of the fins. So basically I have a $300 boat anchor now. Cheapest rebuild I've found so far is $600+ so this thing is finding a new home in the metal scrap bin at work.
$300 well wasted.
Sent from my iPhone using TapatalkLast edited by Voodoo_ChildR32; 08-06-2011, 03:20 PM.1989 R32 Skyline GTR SOLD!!!!
-Bruce Lee
MR FED!!! we are in the same boat. My stocker turbo seal went out on me(stock rb's don't like being spiked to 22psi-via profec b). And instead of an expensive namebrand unit. can i interest you in an really cheap,reliable, alternative?
i actually have one of these(an hx30) and i don't have it on cause havent had the time to take the mani off to get my t3 plates welded. These turbos are cheap and really tough.
I have a question for you though. never removed my exhaust turbo manifold before. should i wait till it's totally cold before removing it or when it's kinda warm??
i don't want to stress the metal before i go and get it welded or does it not matter??
Well, back to where I was before. Bought another used turbo off this forum, and low and behold it blew a ******* seal. So that makes 3 turbos in 2 months. I'm really starting to hate Skylines all over again. I for the life of me cannot figure out what is happening. Everything runs fine for a week or two, then the smoke clouds appear. I think the next step is to stop getting ripped off from the guys selling **** on here and get it professionally rebuilt. I found a place here in Edmonton that can fix it, just waiting on a quote.
-Bruce Lee
Yea man go get it rebuild so you don't take another chance on used turbo. Also If I were you I would replace/ clean our your stock Oil lines. Maybe there a blockage or restriction you don't know about.
Side note' what are you running for a boost controller? Stock? 25 turbos are more prone to failure once push to far past 7psi. Oil cooler would help aswell.Traction is optional, so are zipties
92 Gtst/Silver bullet
Running stock. Boost, no controller. Stock wastegate actuator hits 12psi all day long. My 25 turbo only hits 7psi, but I was going to swap actuators and run 12 psi on the rebuilt 25 turbo.
-Bruce Lee
Originally posted by feyd182 View PostGTR hood and grille to come soon!!!!RB25 Powered RWD GT-R
Sorry to hear about the bad luck man.... As Supraclean stated try changing turbo line. I had my Rb25 turbo last 4 years at 12 psi and when I pulled it out it still was mint. So I don't know. Luck of the draw I guess.
I do like the build so far. I am sure once you have a fresh turbo in there you will fall in love again lol
