rb20 falcon...
    Yes this way its nhra legal so when the disconnect is turned off the car will be disabled so i f running and its dis engauged the engine will be shut off qnd only cables on the car that will be live is the postive cable from the alt
      Starting to look like a car again got the hot side all fabbed and stock dodge down pipe modded , wastegate and screamer pipe done . and bit the bullet and my ls coils showed up yestaurday so ill hopefully have the harness and brackets build before the end of the weekend .
        hot side complete , screamer pipe complete , head studs in , ls coil swap in the process
          Finally got the accesory brackets and belt routing figured out with the drivers side alt and now all the belt have auto spring tensioners , and everything now is on final assembly VGT control is complete , ls coil conversion wired and installed moreless got it all sorted out .
          Heres a video of vgt control in action just working off regulated shop air to see when it moves ,should spool pretty quick for what it is .. The actuator will also be controled via a gm wastegate solenoid running off of a sub injector map with the greddy emanage ultimate . There is also a cable overide to limit the min size of the exhaust side as well as be able to max size overide when on the highway keep backpressure to a min and help with gas mileage ,
          Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
            a few older pics from the last month , with exhaust complete, oil cooler , etc etc . Almost finished building the tune and driveshaft should be done pretty quick so soon it will be on the road
              this is the coolest build thread ive seen on here. props!
              1989 Gts-T Sold
              1992 GT-R Sold
              1991 Gts-T Sold
              1989 Gts-T Sold
                forgot about this thread, comming along nice. lets get a video walk around/ first start up!
                - Adam
                  Double post
                    update i had comepletely forgot about this thread so here is goes i have been busy with the race car lately but this car is damn near ready for the road .
                    fresh interior almost complete
                    quad hid lights
                    the push off battery switch complete with tasca ford emblem
                      link of it with the beginings of the tune im building lol
                      teaser of a couple blips with new rb20det with he351ve turbo
                        Well the car sat all race season and just over a week ago i rolled it back in to finish it and revise alot of lil things that bugged me like cometic head gasket, Cooling/ wiring etc etc trying to get it all done for the lethbridge charity car show next weekend . Coming along very well
                        and when you see this ...
                        you wouldnt expect this i dont think ...
                          More please! Awesome build! Well done!
                            more of what let me know ill post details . more pics of the finish product will come this week with the car show coming up and as soon as i get the timing belt tensioner swapped out there will be dyno results to follow after i bang out a tune should be intresting
                            • #29
                              Are you painting it? (please say no) What will/is the suspension, brake and wheel/tire plan be?
                              • #30
                                NOPE no paint as you see it how it will be for a long time . As for suspension it lowered 2-3 inches in the front and the back variable via air . Plan is to eventually do an irs swap into the back convert the front over to larger disc brakes and go 5 lug but for now I love the petina stock look with the factory wheels and hub caps . I love the attitude the car has with alot of the vintage decals its moreless a car that pictures just cant do justice lol
                                the wastegate screamer pipe ...
