Ok I'm sort of new to the skyline community, i want to take the drivetrain from a r34 gtr and put it in a gt-t or other low end skyline r34 bcs the car and swap are much cheaper than buying a gtr. What are the parts I will need to do a complete drivetrain swap? (Engine, tranny, diff, etc.) I know this isn't an easy swap to do but I'm willing to do it.
Putting a complete r34 gtr engine tranny and awd system in an r34 gt-t
I would question how much cheaper it will be once you're done but you'll need:
The entire driveline, wiring harness', computers, the floor pan MIGHT be different to allow for the transfer case.
There will certainly be more little bits and pieces as you go.
Best of luck!
Thanks, what I've seen done is that they would somewhat mount the tranny and measure it out. Cut a hole in the floor where the transfer case is. Then measure out how big the bulge has to be and then modify the piece they cut out and then weld it back on.
I know of one that was done, but cheaper to buy a GTR. Can bash the GTS floorpan into shape, as it's quite thin single piece metal. Or weld on and use a slide pull tool (used to remove dents) to pull it into shape.
Also you can remove transfer case internals, cut off the transfer case and run it rwd. JGTCC, SuperGT racecars were rwd, not 4wd. RB26 can run 2wd or 4wd sump with custom pickup to suit 2wd sump (Nismo used to sell a rwd sump conversion kit, but not sure if they still do).Last edited by Skym; 08-14-2013, 09:41 PM.RESPONSE MONSTER
buy an r34 GT-FOUR, this will straight bolt a gtr engine and gearbox in. It is near imposable to fit the 4wd system into a rwd skyline as its not the floor you need to cut to fit the transfer case in, it will be the chassis rails. the chassis rails on the 4wd version have the right side chassis rail way closer to the body sill.
Not all the GTRs are coming out of auction at $30k, you can be landed at $20k if you aren't too picky about condition. That doesn't mean the car is a total roach, it just means that the foo foo purists don't want it. Sucks to be them.
Way better off buying a GTR of lesser quality.
