Hey bud, when you swap out the steering wheel, did you end up removing the airbag to get the steering wheel off? if so, was the torx screw on yours was easy to unscrew or tightened pretty bad? how were you able to loosen it up?
Tim's R34 Skyline 25GT-T project
one torx stripped so I had to drill the head off to get the airbag out. Hence why i used the s15 airbag... couldnt get the screw out of the gtt one.Originally posted by 403SKYLINEGTT View PostHey bud, when you swap out the steering wheel, did you end up removing the airbag to get the steering wheel off? if so, was the torx screw on yours was easy to unscrew or tightened pretty bad? how were you able to loosen it up?http://forums.gtrcanada.com/gts-project-cars/39993-infinity-skyline-r32-gts.html
Did you just use a regular drill bit? and did you just drill through that metal piece of the torx ?Originally posted by Infinity238 View Postone torx stripped so I had to drill the head off to get the airbag out. Hence why i used the s15 airbag... couldnt get the screw out of the gtt one.
Well they are tamper proof torx heads, so u need the socket with the hole for the little tab in it. Once stripped I got a small drill bit (just about the size of the screw threads) and drill down threw the head till it popped off. Keep in mind this doesn't get the screw out. I just needed to get the airbag off.Originally posted by 403SKYLINEGTT View PostDid you just use a regular drill bit? and did you just drill through that metal piece of the torx ?http://forums.gtrcanada.com/gts-project-cars/39993-infinity-skyline-r32-gts.html
what socket are you referring?Originally posted by Infinity238 View PostWell they are tamper proof torx heads, so u need the socket with the hole for the little tab in it. Once stripped I got a small drill bit (just about the size of the screw threads) and drill down threw the head till it popped off. Keep in mind this doesn't get the screw out. I just needed to get the airbag off.
Getting my matching door inserts installed today.
Starting to look better on the inside, Not the greatest quallity but not at all bad for a dun it myself.
I'll get some better pics tomorrow after i do some work with the center console.Last edited by Infinity238; 02-11-2015, 11:13 PM.http://forums.gtrcanada.com/gts-project-cars/39993-infinity-skyline-r32-gts.html
Youre not going to match the paint on center console to the stereo, temperature control, and the gauges ?Originally posted by Infinity238 View PostPassenger side done, center console resprayed, shifter surround redone. What a difference it makes. Feels new inside there!
Now for the outside!!!
