Originally posted by BrianV8
View Post
lol i just finished dealing with this problem on my 91 gtst tonite....i hade like 3/4 inch play in the driveshaft/diff and when i pulled away from a stop i would get a clunk in the rearend so i pulled the rear diff out and one of the bearing caps was loose and bent a bolt...
as for the guys that want to shim up the diff (DO NOT GO BIG) I did the same thing to mine and if u go to big u will get wineing from the diff everytime u let off the gas(really anoying and alot of metal shavings)
every diff has different size shimms in it ..mine had a .8mm and a 1.0mm in it and i wanted it to fully lock up so i added another 1.30mm shimm in and that gave me wineing in the diff so i hade to go smaller so i just took out the .8mm and put in a 1.20mm in it and it runs awsome now, good and tight
so i hope this helps u find ur problem
