Well, I thought this was normal with the LSD in the back, but recently, some friends told me the rear end of the car feels "loose" and "clunky" when I drove them.
The more I thought about it, the more I got worried. DAMN THEM!!!
So, I'm seeing if others had any similar issues, and perhaps have suggestions.
It's tough to explain what the feel is.
Here is what's been done to the car for rear subframe:
Aluminum subframe bushing (works awesome, marginally reduced wheel hop, and more stable)
Other than that, it's all stock. HICAS, stock parts etc.
The feel that I experience:
When I roll from a stop, the car "jerks", and makes a noise like I have a brick in the trunk and is hitting the back of the trunk. Only one "clunk", not a consecutive set of clunking.
My rear end of the car feels tight on turns, I don't think anything is loose. Obviously aside from the fact my stock swaybar is too thin and with stock coils, there is a body roll, but no clunking while turning.
Clunks happen when I change gears roughly. I don't notice this problem too much because I rev match all the time and shift properly, most of the time.
If I were to purposely shift early, or downshift w/o rev matching, the ONE clunking noise happens. It's definately from the rear end of the car.
Also, when I'm stuck in a traffic, the car rolls like I'm braking with a severely warped brake. I'm not applying the brakes, but it has that swinging motion back and forth when going, say 10KPH on 1st gear at 1200-1700. Change to second, feel goes away. Every gear has this feel if I'm rolling slowly. Say 2nd gear, 20-30KPH, 1200-1700 RPM.
I've driven this car for a year and never thought about it much, but recently the suggestion my friends brought up are getting to me.
My history: I've never driven a car with an LSD before this, nor drove other Skylines extensively enough to compare.
me if this was an obvious thing that I didn't know, but might as well be safe.
And no, I'm not an idiot for 5spd, I don't stall (engine stalls on its own thx to atmospheric BOV at stops from time to time
bleep throttle once to keep it alive) I don't mis-shift, nor drop clutches like a wacko.
Thanks!
Thanks!
