Originally posted by Skym
View Post
s2 rb25det engine swap into my gtst
I am going to use the s2 coil packs with built in igniter. Can i not use that igniter thats built in to them? I would like to know what i am going to do. I have a rb20 to s2 wiring harness so i think i will be using the rb25 s2 coil packs and no igniterMiss driving sooooo bad! Need to get a car on the road ASAP!
NVCS: It is the V-Tec for Nissan - basically variable valve timing for just the intake side. This was available only on the RB25 motors (DE and DET) series 1, 2, as well as Neo (R34). The Neo actually has NVCS on both intake and exhaust sides. NVCS controls the timing of the opening of the intake and/or exhaust valves by manipulating the movement of the cams. It is the one thing that allows an RB25 to make more power. Without NVCS, an RB25 is not as powerful.Originally posted by cschepp View Postnvcs? Just want to know what that stands for......
And are you saying that i shold go with the auto crossmember? Anyone have one?
It is not a question of having an auto crossmember, but of the holes under your car where the crossmember bolts up.(O||O___SKYLINE___O||O)
SERENITY NOW!!!!!!
Interesting... mine works fine in my R33...Originally posted by BrianV8Actually if using the rb20 ecu u will need the rb20 ignitor and coils. I had an issue that my ecu didn't like the rb25 s1 ignitor box.
The RB25 ignitor is crap anyway...-= ECU UPGRADES =- -= LOCKOUT BARS =- -= AERO =- -= SEATS =- -= ACCESSORIES =-
-= PM ME FOR INFO =-
Can't use the R32 or Z32 ecu then....Originally posted by cschepp View PostI am going to use the s2 coil packs with built in igniter. Can i not use that igniter thats built in to them? I would like to know what i am going to do. I have a rb20 to s2 wiring harness so i think i will be using the rb25 s2 coil packs and no igniter-= ECU UPGRADES =- -= LOCKOUT BARS =- -= AERO =- -= SEATS =- -= ACCESSORIES =-
soooo with the r33 rb25 powerfc you dont think the vvt will work? I wonder why not. The powerfc is meant to be a replacement programable ecu. I would imagine it would work, but if you dont think so please tell me why.
I also dont have the rb25 tranny yet as i want the series 2 transmission compared to the rb25 series 1 transmission. I have heard they are actually very differentMiss driving sooooo bad! Need to get a car on the road ASAP!
yes your right the trannies are very different. The s1 tranny is built like garbage like the rb20 tranny. It can take a bit more power but not that much. The series 2 tranny comes with the good, strong gtr internals. I fluked out and got my series 1 motor with a series 2 trannyOriginally posted by cschepp View Postsoooo with the r33 rb25 powerfc you dont think the vvt will work? I wonder why not. The powerfc is meant to be a replacement programable ecu. I would imagine it would work, but if you dont think so please tell me why.
lol
Remove R33 RB25DET cams with NVCS and fit R32 RB20DET cams + adjustable camgears. Then remove series 2 coilpacks, remove series 2 ignition module. Then run R32 RB20DET engine loom, etc + R32 RB20DET ignition module, R32 RB20DET coilpacks, etc, R32 RB20DET ECU with Nistune.
R32 RB20DET, R33 RB25DET cam specs -
They are similar lift, duration wise.
This has been done before in Australia (S14 drift car with RB25DET engine) and produced 414rwhp with GT3076R turbo with 0.63 exhaust housing.RESPONSE MONSTER
