Originally posted by Skym
View Post
s2 rb25det engine swap into my gtst
I am going to use the s2 coil packs with built in igniter. Can i not use that igniter thats built in to them? I would like to know what i am going to do. I have a rb20 to s2 wiring harness so i think i will be using the rb25 s2 coil packs and no igniterMiss driving sooooo bad! Need to get a car on the road ASAP!
Originally posted by cschepp View Postnvcs? Just want to know what that stands for......
And are you saying that i shold go with the auto crossmember? Anyone have one?
It is not a question of having an auto crossmember, but of the holes under your car where the crossmember bolts up.(O||O___SKYLINE___O||O)
SERENITY NOW!!!!!!
Originally posted by BrianV8Actually if using the rb20 ecu u will need the rb20 ignitor and coils. I had an issue that my ecu didn't like the rb25 s1 ignitor box.
The RB25 ignitor is crap anyway...-= ECU UPGRADES =- -= LOCKOUT BARS =- -= AERO =- -= SEATS =- -= ACCESSORIES =-
-= PM ME FOR INFO =-
Originally posted by cschepp View PostI am going to use the s2 coil packs with built in igniter. Can i not use that igniter thats built in to them? I would like to know what i am going to do. I have a rb20 to s2 wiring harness so i think i will be using the rb25 s2 coil packs and no igniter-= ECU UPGRADES =- -= LOCKOUT BARS =- -= AERO =- -= SEATS =- -= ACCESSORIES =-
soooo with the r33 rb25 powerfc you dont think the vvt will work? I wonder why not. The powerfc is meant to be a replacement programable ecu. I would imagine it would work, but if you dont think so please tell me why.
I also dont have the rb25 tranny yet as i want the series 2 transmission compared to the rb25 series 1 transmission. I have heard they are actually very differentMiss driving sooooo bad! Need to get a car on the road ASAP!
Originally posted by cschepp View Postsoooo with the r33 rb25 powerfc you dont think the vvt will work? I wonder why not. The powerfc is meant to be a replacement programable ecu. I would imagine it would work, but if you dont think so please tell me why.
I also dont have the rb25 tranny yet as i want the series 2 transmission compared to the rb25 series 1 transmission. I have heard they are actually very differentlol
Remove R33 RB25DET cams with NVCS and fit R32 RB20DET cams + adjustable camgears. Then remove series 2 coilpacks, remove series 2 ignition module. Then run R32 RB20DET engine loom, etc + R32 RB20DET ignition module, R32 RB20DET coilpacks, etc, R32 RB20DET ECU with Nistune.
R32 RB20DET, R33 RB25DET cam specs -
They are similar lift, duration wise.
This has been done before in Australia (S14 drift car with RB25DET engine) and produced 414rwhp with GT3076R turbo with 0.63 exhaust housing.RESPONSE MONSTER
