how much boost can the RB25DET motor handle, stock?
RB25DET max boost?
alright i went through that issue a while ago. here is the result of a month of research and what i've currently done with my car.
Series 1 stock turbo can handle 1 bar all day long. Series 2 stock turbo can only handle a MAX of 12 pounds due to the plastic compressor wheel.
The motor itself
As long as you have all the proper supporting mods it can do a MAX of 18 psi. Not the most reliable though in my books.
What i did with my motor, throw in some ARP head studs, oem head gasket, motor should be bullet proof to 24 pounds with all the supporting mods but be carefull. Any more than 450 Crank hp, apprx 400 wheel hp you max the internals can't take it anymore.
My car is setup with arp head studs, oem head gasket, 20 pounds of boost all day long, had it up to 23 on the dyno, and making 380 wheel hp after detuning on a mustang dyno which is approx a true 400hp wheel due to mustang dyno's reading a little low
I'm guessing my R34 Neo 6 GTT turbo is most definitely ceramic exhaust wheel then hey? Damn. I had a feeling, but I was really hoping it was steel.
I've been foiled.DISCLAIMER: If any of the above comments in this post hurt your feelings you are likely taking me too seriously; I'm probably just busting your balls. If you're unsure, feel free to PM me and we can discuss the matter privately, as to not pull the thread OT.
woo!
Sweet. I will double check and I will be cranking it up after fuel upgradesDISCLAIMER: If any of the above comments in this post hurt your feelings you are likely taking me too seriously; I'm probably just busting your balls. If you're unsure, feel free to PM me and we can discuss the matter privately, as to not pull the thread OT.
Yea running an RB20. But I know it is most definitely a ball-bearing turbo. BACK OT!DISCLAIMER: If any of the above comments in this post hurt your feelings you are likely taking me too seriously; I'm probably just busting your balls. If you're unsure, feel free to PM me and we can discuss the matter privately, as to not pull the thread OT.
