ya i've got a series one and i'm at 400 wheel on stock internals, think thats as close as i want to get to 450 crank
RB25DET max boost?
i've heard of people running more than 15 pounds on the series one turbo's, don't expect it to last forever though. series 2 turbo no way. If you want to run that kind of boost with a rb25 turbo it has to be the NEO. Even then at 8 grand the neo turbo tends to dip off due to not being able to flow enough air
I noticed Japanese tuners don't push stock RB25DET internals past 415whp max (high boost setting) with headgasket upgrade. Then it's time to fit lower compression RB26 bottomend inside RB25 shortblock.
It drives like this when you have a boosted up RB25DET bottomend with high mount single -
Me in my Nissan Skyline R33 GTS-T having a play around at pukekohe Raceway in New Zealand. This was my first Track racing experience ever, before this day I ...
With RB26 bottomend -
Few laps at Pukekohe Raceway New Zealand in my GTS-T. Not edited no music! (Cars sound good anyways) enjoy.. :)
Note it sounds a little bit different.
With stock turbo they don't push past 13.23psi (low boost, everyday setting) to 16.17psi (high boost setting, mainly used for overtaking or dyno).
Some outside Japan have produced up to around 322whp with low boost level of 12-13psi with stock RB25 turbo (using a MAP ECU, so no MAF sensor restricting intake). I assume it's a Series 1 RB25 turbo.
The Series 2 RB25 turbo's do fail on compressor side of turbo.RESPONSE MONSTER
speaking of r33 turbo and tuning, does anyone know anyone around the nova scotia area that can tune my r33 gtst? the japanese owner only put 35000 kms on it and it still cuts out and, im not saying its slow but, i want it faster. XD'94 Skyline R33 GTS-t
Build Starting This Summer...
[OO\_SKYLINE_/OO]
It does with R32 RB25DE head.
Not sure about R33, R34 RB25DET head, as it has VVT. But might be able to be modified to fit if VVT is sorted (I think oil feed??).
I think the differences are mentioned in the RB30 guide, which RB30 would be a better upgrade bottomend wise for hp (RB26 bottomend for response) -
400whp+ RB30 in a R33 chasing down a WRX (inside, out side shots) -
Nissan Skyline R33 GTST, driven by Reuben York (with no power steering) at Levels Raceway, Timaru. Custom built RB30 making 400+ whp by Rapid Performance. Ch...
Gives you an idea what it drives like. Just need wide rear tyres with slicks or semislicks to get some traction (RB30 = alot of torque).RESPONSE MONSTER
Originally posted by cschepp View Postok..... would a rb26 bottomend be a direct bolt up to a rb25 head? And I am going to be running a big single so i dont have to worry about f'ing the turbo up... just the motor.
cschepp, we can't tell you how much a complete rebuild would cost because everyone's definition of "complete" is different. at 600 atw I would guess the shortblock would be the cheaper part of the build in comparison to everything else.
