Basically the problem is my #4 Cyl is doing nothing. When I run the engine all my other pistons are moving fine, when I disconnect the wiring from the coil on all the other cyl. the engine sounds different, but on #4 nothing happens stays the same.
It causes the car to shake, idle high, then low, makes it sound loud and rough. But the car still drives fine, just not as powerful.
I have tried everything I could. Swapping 2-3 differnt plugs and coils into the cyl. got a brand new wiring harness, new ignition module, coils are brand new Yellowjackets, the plugs only have roughly 5k on them, and they all work fine in my #1, and #6 cyl. compression is 90 - 100lbs in the cyl. when I pull the plug out the tip is damp and has gas on it, and when I look down the top of the piston looks damp, so gas is getting in there.
Now theres one of two posssabilities that I have come to a conclusion and I am not sure if this might be a common problem with RB20 engines, so I might as well give my thoughts out there and see what people think.
When I remove the oil cap and smell the oil (or the dip stick) it has a strong gasoline smell to it, and the oil is extremely thin, even when not hot. So I am thinking maybe the injector has been flooding the #4 cyl. causing gas to seep down the side of the piston and thining my oil, but then why isn't that one cyl. just not running to rich? I don't seem to get a spark at all!
So it brings me to my second theory of why it might not be firing, it might be an electrical problem, everything from the Ignition module to the plugs is pretty much brand new, and works perfectly fine, I have determined that the coil is sending a spark to the plug, as I have lifted it while the engine was running and noticed little archs and 'popping' noises when I did so.
Could this be a ECU problem? If so how would I diagnose a problem with my ECU?
I have yet to change the oil completely to see if that might be the case, I am planning on draining the oil today, and pulling out all my plugs, and one cam cover to let the engine dry out of all gas (let it evaporate) and then put in some new oil maybe tomorrow, but I highly doubt it's a mechanical problem and it's more of an electrical problem...
ANY help will be appreciated, this shaking and lose of power is driving me nuts!
