so ive been having a hesitation above 5200 rpm for a while and i think ive got it figured but want to double check with the smart guys on here.
i have a 91 240sx with rb20det... basically stock without fmic and running 12.5 lbs of boost.
i checked the ecu and its giving me code 34(knock sensor). i have gone through every single thing on the "fix your hesitation" list and no results. i am running perfect a/f ratio and i know my coils are good... running the proper spark plugs, have enough fuel(obviously since no leaning out) ect ect...
so heres my hypothesis. ive been reading up a lot on nissan motors (sr's ka's vg's and b13 motors) and it seems that the obd1 versions of the motors apparently commonly will throw the code for the knock sensor, and although the resistance of the knock sensor is fine, the pinout on the ecu is fine, and after replacing everything, it still gives the code.
i have only found this on 2 or 3 threads which do not involve rb's, but the ka's and b13's. apparently the harness(being a shielded wire to eliminate some interference) can wear out quite bad and actually make the wire have a higher continuity and therefore cause a code to be thrown. additionally, the ecu apparently will only throw a code when the knock sensor or wiring is faulty, not when the motor is knocking. and as a result of this shielding killing the connection, replacing with ordinary 16 gauge wire can actually completely eliminate this problem (as some have stated).
i am just wondering if anyone on here has heard of this with rb's or could confirm any of the information written above. ive searched all of gtrc and google and not come up with anything.
