One of the symptoms of leaking intake manifold is missing at idle (lean missfire). If engine knocks, ECU can protect engine via running engine rich (knock maps), which could make engine miss at high rpm's. Spraying head to intake manifold joint can make engine note change, which means there's a intake airleak.
If knock sensor is faulty, ECU should engage safety revlimiter at around 5000rpm.
