Hey all, just acquired a GTS-T yesterday, having some idle and accel problems. When I first startup after its been sitting for a long time and is dead cold, does the usual 1500'ish rpm, then settles down to 8-900 while still cold, and gradually will start having trouble and stall from there unless I give it a tap on the gas to keep it alive. After giving it just a tap, it goes back up to near 1000 and stays steady then slowly starts dropping back down to where it wants to stall. This tends to happen until the car is warmed up, so I've observed. Am I right in guessing that cleaning the cold idle adjustment would likely help this?
Another problem I have, that is kind of random and doesn't happen 100% of the time, but maybe half the time is that my idle sits up around 2000rpm, and when off throttle and decelerating, the car will lurch every few seconds seemingly as if I'd be giving it a slight tap on the gas. Now when the car isn't doing this, its idling normally etc. Possibly a problem with the TPS?
I took off the MAF and cleaned that today, and reset the ECU. The only code I got off the ECU was the "54 - Auto signal to ECU". I'm assuming that has something to do with an auto tranny, as the car was originally an auto, swapped to manual. If it doesn't, anyone know what it means? I suppose tomorrow I should pull the idle control , cold idle, throttle body, and just give everything a good cleaning to see if it helps. Any other suggestions?
