Hello boys! I have a little problem with my boost controler i just installed. Ill explain in details what i did to make it simple.
Frist of all, I own a R32 GTS-T Type m, with the RB20det engine. I recently baught off RHDjapan a HKS Evc-s boost control and Splitfire coilpacks, that I installed at the same time.
The car was going #1 before installations and after the problem that occured was:
when i started the engine, my RPM was very high 2000 RPM up from 750-850 originally at idle speed. So i told my self, heh new parts gonna give it a min or two to set up, but after id say about 50 seconds, i got a rpm drop to 1000, then back up, the back down to 1000, then back up all of these up and downs had about 2-3 seconds inbetween each. I gave it a little gaz to see what would happen, braught the rpm from 2000 to 2200 and the car acted as if it was on a launch control, meaning that the rpm was going up and down +/- 100. *all tests where while car is on neutral*
How i plugged the boost controler: I cut the hose that was going from the fuel pressure regulator to the intake manifold(if we can say) and put a splice in between with a air filter, that goes to the HKS boost sensor. Second thing i did was unplug the wastegate hose, put a piece to put 2 hoses together in place, added a hose that went from the original wastegate hose to the "NO" solenoid enterance (meaning that the compressor hose goes to the "NO" enterence). At the "com" solenoid nipple there is a hose that starts there and ends at the actuator.
I though it coulda been a vacuum leak , searched and found nothing, if you guys still think its a vacuum leak after reading my post tell me, ill plug the smoke machine.
I have also 2 little questions:
1- The NC solenoid hole, do i have to take the cap off or keep it clugged?
2- Could it be my splitfires that arent connected to spark plug properly? (doubt that one but might as well ask)
Please help me out.
Please help me out.
