You'll need someone with a similar car, engine and note the rough position of CAS to get engine started.
Also if cambelt is off by a tooth, engine could run rough and probably have starting problems. Compression test or removing top cambelt / timing belt cover and checking that cam gear marks line up with marks on backing plate behind camgears should help to confirm this.
