hey guys just wanting to know, i have 550cc injectors and a 255 lph walbro fuel pump that are waiting to be installed, and i am wondering if i get a nistune daughterboard (which i am planning on doing) will i still need a fuel pressure regulator?
Will I need a FPR?
so i had a fuel pressure regulator and it crapped out. put stock one back in.
i have 255lph fuel pump and 550cc injectors waiting to go in. will i need an fpr?
i was looking at the stock looking adjustable fpr. but then i would need a gauge right? or else how would i know what the pressure is?sigpic
Originally posted by m_melen...it woulda been safer if his harness were made of jello
It's best to check FPR (pull vacuum hose off FPR and see if fuel pressure rises 7.1psi or so) and upgrade if necessary. Nothing last's forever.
Check fuel pressure via fuel pressure gauge that's plumbed in between fuel filter, fuelrail. I think fuel pressure is around 35.5psi for RB20DET at idle with vacuum hose connected.
Can fit a aftermarket fuel pressure gauge in cabin with sender in engine bay.
Nismo sell a adjustable FPR to raise fuel pressure and I think damper FPR to match.Last edited by Skym; 03-14-2011, 01:26 PM.RESPONSE MONSTER
Quick easy thing is get a aeromotive fpr. I have one and it says it on the gauge stuck to the fpr. Now if you are wanting to know your fuel pressure on a regular basis I would suggest simply buying a gauge and monitoring it that way.Miss driving sooooo bad! Need to get a car on the road ASAP!
