Car is a 92 gts-t
Alright, hopefully someone can help me on this cause im about to lose my mind haha.
I had a fully functioning cluster in the car before 2 days ago, everything worked fine I just wanted to swap in a new one because the blue colour doesn't work with what im doing in my car.
I purchased a Cluster with grey faces over winter, and went to swap it in yesterday. Switched in my LED's to the new cluster and put it in. The Tach did not work and when hitting the left turn signal the outside light would work but the light inside the dash would not, even with a fresh bulb.
So I took it out, and put my origional Cluster back in and everything worked 100% fine.
Today I figured I would just take off the faces from the broken cluster and put them on my working one because thats all i really wanted anyway. So i get them off and put them on my working cluster, everything looks good so far.
Put the "working" cluster in the car with the new faces and now nothing works (except oil).
-Boost gauge doesn't work at all
-Speedo doesn't move (although that could just be position but it stops at 175 if you move it, which doesn't seem right)
-Tach started working a bit but is super delayed
-Gas keeps going to completely full
-Door light doesn't light up
I don't think that taking the needles off would cause a cluster to stop working, I understand that things might need to be re-calibrated but they shouldn't just stop working like this.
Does anyone have any suggestions? Or should I just get a new cluster all together that already has grey faces on it?
Thanks,
Anthony
Thanks,
Anthony
if you take the time it can be done haha
wish i knew that before i got rid of the tomei lol
