Alright so i decided id just put the issues im having in this thread and see if anyone can answer them.
First off, not getting full boost. read about it here: http://forums.gtrcanada.com/general-...tml#post459515
Secondly, my front tires are both closer to the back of the fender causing rubbing when cornering. I have new Tension rods here, any ideas if that will fix this? Also putting new tires on and the new tension rods and then getting an allignment done. Hopefully that clears up this issue.
Slightly rough idle, rough start after sitting. Every morning when i start the car the idle is low, kind of boggy and revs up and down for 30 - 45 seconds, then goes up to 1500, then slowly drops to around 1000. Car idles at about 900 once warm (all according to original tach in car)
Car is running rich, BOV is venting to atmosphere and i have been told that could be the issue. Have also been told that it might be my MAF since the cars having a rough idle. Or that it might be my AAC? How do i go about cleaning my AAC and (probably noob question, first JDM vehicle) where is it located on the engine?
I plan on getting a front mount intercooler, aluminum rad, new turbo (T3 maybe?) with boost gauge and run around 12 PSI, gtr fuel pump and injectors. Any suggestions on parts to upgrade to make the car run better, faster and stronger will help. dont want like 400 HP, this is a DD but i like to have fun at times.
