I was driving to work this morning and made it 4kms away from my house and my car started sputtering so I depressed the clutch and it died, when I released the clutch again the car began sputtering again till it died.
Got it to a parking lot checked to make sure I had all the plugs attached because I was checking the spark plugs the night before. Looked around everything was still attached so I put the car in the on position and tested the tps to male sure it was firing the injectors were firing and they we're.
I then went to the ecu and pulled code 21 (ignition signal) so I thought it was the ignitor but tested it in my buddies car and it was working.
So that brings me to where I am now having a busted car so I need some help. Ive read on various sites then it might be the ECCS or ignition signal relay behind the ecu. Any ideas?
