Why cant i build boost in first gear? I have no problem in any other gear but im just wondering why when im in neutral or parked i cant build boost to show off my bov? Thx
Boost?
Lol if you keep your foot to the floor long enough it will always get to 10 pounds, not saying you have a huge leak but enough. get a tester and test it. Chances are thats the issueOriginally posted by gtst_skyline View PostNo leak. I can build 10lbs every time and hold it there. The wastegate opens tho. I think i might be building boost but neither of my gauges show boost at all
You may just be experiencing what is commonly called boost lag. Depending on your turbo, it can take up to 4-4.5k rpm to reach full boost (that's on a GTR, dunno about GTS) when going from a standstill.
Do you have a boost controller? If so what make/model?
If it's an Apexi AVC-R it has gear and rpm based boost settings and might not be set up correctly. This is likely not your issue but I'm just throwing it out there.R32 GTR FULL SERVICE MANUAL DOWNLOAD:
Don't understand this thread seems to bee all over with answers. You CAN build boost in neutral just got to RPM alot higher like around 6k+. Building boost before "launching" is not uncommon in racing. Not building boost in first gear though is weird, seeing as its a short gear though your probably shifting before it happens(?), but yeah the engine got to be under load for normal boost to happen... in my GTS spooling usually starts around 2-2.5k RPM and peaks around 4k ish... punching it off the line in first you should be able to HEAR it boosting yet alone feel it...
AAAND if none of your gauges aren't showing any boost then yeah you got a leak... vac lines running to the gauge(s)... unless i read that part wrong.
What kind of BOV you have? could be it's not functioning properly and bleeding...You gotta pay to play.
Originally posted by Ghost View PostAAAND if none of your gauges aren't showing any boost then yeah you got a leak... vac lines running to the gauge(s)... unless i read that part wrong.
My gauges show boost in second through fifth so the gauges are working properly. And the BOV is a vibrant synchronic bov.
Remember that most of your "boost" is generated from the HEAT of the exhaust gas, not its velocity. Your motor is not going to generate much exhaust heat at zero load even if you're cranking it at higher rpm.'93 R33 Gts25T Inked Art Car - SOLD
at www.inkedartcars.com
