So my car has been misfiring lately. It will run great then out of no where a cylinder just shuts down. the engine shakes badly and struggles to rev up and get the car going. I thought it was the wiring harness so i replaced it, still have an issue. swapped around all the plugs and coilpacks, replaced 2 coilpacks (each was thought to be the problem) but its still misfiring. Then i started looking at injectors, i put injection cleaner in and the next day, the car ran great, every cylinder was running, worked for about 3 days then today i put just straight 94 octane gas in with no injection cleaner, got home, let the car sit for about an hour, maybe 2, went outside and started it to go to town and all of a sudden it was misfiring right away. it went away after a couple minutes of driving, picked up some injection cleaner, put it in, and the misfire came back once again, drove the car for about an hour with it missing, really bad back fires when letting off the gas, let the car sit for about 20 minutes while i researched online wtf i can do about this to try and narrow it down, grabbed a metal pole to listen to each injector, started the car (had only sat for maybe 20 minutes) and all of a sudden its running again without a misfire.. anyways i went ahead and listened to each injector, i can hear them all clicking.
2 months ago i replaced the fuel filter, cleaned the MAF and resoldered it, cleaned the AAC. I know i have a TPS issue because every once in a while the slightest touch of the pedal will make the difference from almost bogging down to smoothly accelerating, enough to jerk your head back and with just the slightest touch of the pedal. new coilpack wiring harness, swapped 2 coilpacks, new plugs 2 months ago, new battery terminals, grounded coilpack harness and ignitor harness directly to the battery.
i have absolutely no ******* idea what this is anymore and no one seems to be able to help at all. no shops willing to even take 3 seconds to look at the car cause its an import and that deams it impossible to work on i guess. Anyways, i would just go ahead and swap coilpacks, ignitor, another new harness, new injectors and a new injector harness BUT i dont have the money to do that unless someones willing to part ways with all of those for about $100.
Is there ANY way i can check a coilpack to see if its ****** or not? is there anything that the spark plugs might be able to tell me? is there any way to tell if an injectors ******? how can i check my ignitor? could this be a ground issue? i found a loose ground but no one cares enough to help tell me where the **** it goes. i just need some helpful opinions on this, anything i can do to check coilpacks, ignitor, injectors, etc.. i am 100% out of ideas and almost out of money all because of this stupid issue. im sure its either a coilpack, injector, or ignitor. I dont have the money to replace all 3 though so i need a way to test them.
Video of how the engine sounds at idle and revving, also how the car starts. It usually only struggles the first time i start it in the day but sometime struggles a tiny bit when starting like in the video. This is how the car sounds when its running good.
