It normally runs on 100 octane or so in Japan. But the octane ratings in Japan and downunder in Australia, NZ are different to USA, Canada (where there's Skylines). Downunder there's 98 octane at pump, but can run E85?, etc.
Didn't notice any missing on my car when the studs snapped, but leak probably wasn't big enough. 1st, last studs breaking are common due to exhaust swinging around (all of the exhaust studs are meant to be changed every 10 years or so). Also change hanger bushes for exhaust, as they are usually the cause due to age, fatigue (stretched). Some put a flexi in front pipe (like you do on Honda's) to prevent this problem from happening again. There's a stud and a coil. The stud screws into middle of coil (coil fits into stud hole in head) and there's 3x stud sizes from memory (I think screw part on stud on head side has a different thread size hence the different sizes for studs, coils). Can buy them from Nissan dealership parts department if you know the part number.
It could be a leaky injector if intermittent which does make it sound rough and could make engine knock (or sound like knock which ECU picks up), like running on 5 cylinders.
