Result 209hp goal 220hp(OEM)
My goal this summer was to get this beet up type m back to OEM spec, safe and reliable.
I wanted to learn how to get a skyline smooth running.
building power will come later.
first dyno was 194hp running lean, with spikes in the graph and belts flapping. "dangerous!!"
1. A new walbro fuel pump balanced out the air/fuel ratio
2. timing belt, tentioner, idler bearing,water pump, splitfire ignition coils, cam sensor, igniter,corroded wires to the ECU solved the spikes.
3. compression test 150 across
4. extras- 3" HKS cat back exhaust, 18" rims,hsd coil overs Apexi air intake
I am happy with the results. honestly I though the work I did would get over OEM hp.
The car is almost 20 years old but what else can restrict OEM power?
The only things I have left are:
-wires to ignition coils are old
-release bearing on clutch is making noise
-timing could be adjusted
-Could tune ECU for 94octain
-Plugs are OEM #6 should go to #7 for the splitfire's
Any thoughts
OLD DYNO RESULT
NEW DYNO RESULT
Any thoughts
OLD DYNO RESULT
NEW DYNO RESULT
