I have a 92 gts-t running 12psi boost. i have got he BCPR6EIX-11 NGK plugs i was wondering is you knew what gap they should be set at. i hear its very important
Tune up Guide RB20DET GTS-T
This is a sticky topic.
anyone know when the timing belt needs to be changed? (how many kms)
also, what else needs replacing at that time? (eg. water pump, gaskets, etc.)
thanks1966 Pontiac Beaumont | 1972 Nissan Skyline 2000GT-X | 1990 Nissan Skyline GTS-T Type-M
1991 Toyota Celsior C-Type Supercharged | 1991 Toyota Cressida | 2008 GMC Acadia
The "-11" in the NGK plug # is pregapped to 1.1mm. I dont think those plugs are meant to be gapped. If u want .8mm you need "-8" plugs.Originally posted by caldwellI have a 92 gts-t running 12psi boost. i have got he BCPR6EIX-11 NGK plugs i was wondering is you knew what gap they should be set at. i hear its very important
100,000km, and you might aswell replace the water pump, timing belt tension, and idler puller while everything is apart.Originally posted by Boyscout View Postanyone know when the timing belt needs to be changed? (how many kms)
thanks
the pulleys like to rust out with age and will eventually give out which could lease to the valves contacting the pistons wen the timing belt falls off.
ONE huge note to this:Originally posted by Skym View PostIt's actually 110,000kms, but 100,000kms is a good time to change cambelt, etc. If car is thrashed, change cambelt every 60,000kms.
It's 10 years or 110,000 KM, whichever comes earlier.
a local owner slipped his belt (due to age) and his car was at mid 60,000KM. If you imported a Japanese car, I'd recommend doing it anyways for a peace of mind (and idle/tensioner/spring also)
little known fact, the gtst-M only takes Fiji water for power steering fluid.Originally posted by huvadub View Postwhat do i uae for powersteering fluid? I have a 90 gtst -m with hicas....
mine looks like ATF but I haven't replaced mine yet, anybody else use ATF?I've been brushing my teeth with jack but it's resulted in terrible amounts of tooth decay.
