Skyline R32 GTS-4 rear outter tie rod?
  • Skyline R32 GTS-4 rear outter tie rod?
    hey, i have been searching this for awhile, and i had no luck. well im looking for rear gts4 outter tie rods? anyone know what USDM nissan part would fit this? any where i can source these for a good price?
    I'm thinking it was the 300zx 2+2!?
    aww crap, did you see that!
      can anyone confrim what fits forsure? im pretty sure its the same as the rwd skyline?
        I think I tried those already and they are not even close to the Skyline rod ends.
        1989 R32 Skyline GTR SOLD!!!!
        -Bruce Lee
          im pretty sure the rwd tie rods will fit? if they do, i have access to one, i should pick it up and maybe compare them to others? i really gotta get this fixed.
            If your lookin for just the Rear Tie Rod Ball joint assembly, Parts Master says Z32 VG30DTT, R32 RB20det 2wd and 4wd, R32 GTR are all the same Part #.
            Go to Nissan and be done with it. Ball Joint Assembly - Rear Axle - 55154-30P00.
              I also need the Outter tierod end with the ball joint. So does anyone know what exactly fits on the gts4 before i go insane.
                The GTS4 ones will fit perfect! I might have some at the shop, will have to check next week when back in the office.
                RightDrive Inc. Parts Manager
                  Front or rear?
                    Rear outter tie rod
                      300zx twin turbo. Not the na version. These should fit as the Gtr parts are the same as well.
                        Hi Everyone,
                        Please - no one kill me for reviving an older post as I'm merely trying to be helpful... I wanted to offer the Nissan Part Numbers that I have looked up on "FAST" for Tie Rods (Front and Rear) for R32's... Of course the "Rears" only apply to HNR and BNR models... I own an HNR32 with a RB26 Swap in it so I know all the advise people tend to give who think they know about Skylines but don't own one, or peeps that only know about GTS-t's... Then there is the majority of folks who have a good bit of actual knowledge and make me want to help... So I do understand that the small group of us HNR drivers are the somewhat "hybrid" of the GTS-t and GT-R platforms... So before anyone trolls me - I know what I'm talking about.
                        (Front)
                        SOCKET KIT-TIE ROD, OUTER -- 48520-33P25 (alt 48520-33P26) Also appears to be a 300ZX part number on nissanpartszone.com $76.39
                        SOCKET ASSY-TIE ROD, "INNER" -- 48521-10V06 (alt 48521-10V08) Also appears to be a 300ZX part number on nissanpartszone.com $134.09
                        (Rear)
                        LINK-LOWER, REAR SUSPENSION, OUTER -- 55114-39F10 (Driver Side) Also a 240SX part number on nissanpartszone.com (I didn't know they made HICAS 240's? Or do they use these on the front?) $47.61
                        LINK-LOWER, REAR SUSPENSION, OUTER -- 55114-39F00 (Passenger Side) Also a 300ZX and 240SX part number on nissanpartszone.com (again on the 240's?) $47.61
                        SOCKET ASSY, "INNER" -- 48521-35A06 Also appears to be a 300ZX, 240SX and Sentra part number on nissanpartszone.com (...and the Sentra's too?) $61.42
                        Notice the "INNER's" really aren't called "Tie Rods" but rather "SOCKEY ASSY's"... I think the Tie Rod boots are part of the whole OUTER Tie Rods too - so I've not seen any info on separate boots being available in case anyone was looking. I've looked at a couple of prices on other sites and I thought I found a few for as low as $35.00, but I don't recall if that was OEM or not. You may want to also check your ball joint boots for rips before starting this job...
                        As always, I hope this post is helpful to peeps out there... If anyone needs a screen shot from Fast, just shoot me a PM.
                        Ken
