Wanting to do Holset HX40 turbo on my R33 - need to know what it invovles
  • Wanting to do Holset HX40 turbo on my R33 - need to know what it invovles
    Hey guys, I'm currently sitting without a license without **** all to do, so I'm going to start building MR R33
    I want to do a turbo upgrade, and I was checking out a few videos on youtube and one guy has an HX40 setup on his and it looks pretty nice, he's saying around 500-600 bhp and on a stock block no internals done which is kinda what i want, don't want to have to take it out and apart if i don't have to you know what i mean
    now i see these turbos for decently cheap around "thebay" but i am not sure if they are genuine holsets or knock offs
    I'm reading into it a little bit and I know iLl need to get a top mount manifold, anyone have any idea where to get one? the thing that confuses me is the plenum, do i need to have a front facing plenum too?
    this is my current setup its pretty stock so i need to know what i'll need for this project then decide if it's worth it or not for me
    3.5" exhaust
    greddy front mount intercooler
    apexi bov
    2.5" piping (mite need to upgrade that)
    hks mushroom intake
    hks evc4 boost controller
    3 or 3.5" downpipe (not sure on kind)
    stock ecu
    any info would be much appreciated as i'd like to start collecting parts asap
    25 bottom end will only take 400whp if you want it to last. There are claims of 500+ on some of the auzie forums but it all comes down to reliability.
    I'm currently collecting parts to build my 25. IMO key to reliablity is build the motor to handle 200hp more than your planning to make.
    IMO this is your shopping list.
    Forged Pisons and rods. I got mine on the ebay combo deal also but watch who you buy from. Make sure its legit.
    Acl Race Bearings
    Balance rotating assembly
    Block and Head decked for metal head gasket.
    Heavy duty clutch
    Big intercooler
    Might get away with 2.5" intercooler pipe, i went 3"
    44mm+ wastegate
    750+cc Injectors
    Walbro fuel pump
    upgraded coils
    Cams make power easier
    upgrade oil pump
    Tune
    If you really want to get intensive with it, port polish head
    valve springs
    clean up valve seats
      thanks for the reply dude, but like i said I dont' want to open up the block quite yet, I want to go with this holset setup on stock block and see what it can do, if it blows up then sure i'll build up the block but I don't want to open it all up and pay for internal parts quite yet, do you happen to know what needs just for that holset turbo to go on? I'm assuming i'll need that top mount manifold, some kind of plenum front facing (confused on this) , my intercooler should handle it with no problem but I am not sure its pretty huge front mount, injectors? fuel? ecu/computer/some kind of tuning? clutch?
        here's my car
          R33 Nissan Skyline GTS-tRB25DET (Internally stock)GReddy Style Intake PlenumQ45 ThrottlebodyHDI Front Mount IntercoolerS-TEC Stainless Topmount ManifoldTurbo...
          this is the vid of the guy that inspired me
            i had a holset on my car before i went with a good turbo. I had an hx35 it was laggy as hell, hx40 on stock motor would lag so bad would be undriveable IMO. Only way to make a big turbo like that work is madure head work.
            But if your ademant about it this is what you need:
            Top mount manifold. Ebay one will work, just brace it so it won't crack on you.
            custom downpipe
            custom oil lines
            re rout coolant lines
            44mm+ waste gate
            front facing manifold
            q45 throttle body
            750cc+ injectors
            water meth system if your attmepting this on a stock motor
            walbro 250 fuel pump
            good a/m coilpacks
            colder spark plugs
            heavy duty clutch setup
            3" intercooler pipe
            Think thats pretty much it to effectivly blow up your motor haha.
              that movie proves the lag i'm talking about just full throttle driving, listen closely how long it takes for the wastegate to open between shifts, a good responsive turbo with the same flow as that turbo will spool in less than half the time
              Biggest give away is when he's rolling on the gas while your watching the tach and listen for the waste gate, he's not making full boost till almost 6 grand,
                hmmm ok, any ideas on a turbo that is not super expensive but an upgrade over my stock one? ideally one that would just bolt right up would be sweet but i'm likely not going to find that haha
                and i have a F1 racing stage 3 clutch 6 puck, I put it in the summer time, I don't know if that will hold much but that's what I have.. It was definintely a cheaper one from ebay but it seems good as of right now but with more power not so sure , I'm on a budget tho, I'm not one of these guys that can spend a zillion dollars on top name parts, I wish I could but I'll be going back to school and rent to pay so that's not an option for me right now
                thanks dude
                  For numbers you want to make, spend money or your wasting your time, So much work in making those numbers you'll be throwing money away doing it twice.
                  I had that f1 stage 3 on my old motor, after 300whp started slipping. Best bang for buck clutch to hold numbers you want is the ACT XTD series rated to hold 630ft lbs. Run you around 600-700 bucks depending where you buy
                    I don't necessarily want to make 500+ hp, I was just throwing a number out there I heard that holset can make, I'd be happy with around 350-400 whp , that's still damn quick, I'd be good if I could break into the 12's 1/4 mile, i think 350-400 whp would put me in the 12s eh?
                      my car is putting down a bit over the 400 mark when it decides it wants to run good haha. But ya i've run 12.5 with a shitty launch and street tires. Good launch and slicks should have you close to low 12's if your lucky touch 11's
                        Best combo for this setup is a
                        gt3076 turbo or equivelent,
                        550 cc injectors
                        38mm wastegate
                        250 walbro fuel pump
                        fuel pressure regulator
                        your choice on 2.5 or 3" intercooler pipeing
                        good tune
                        probably going to need an uprade for that f1 clutch
                        Thats about it. 400hp on a 25 is relativly easy
                          That's my car
                          It makes full boost by 4100 rpm, I've driven the car on this set up as a daily driver hitting full boost daily for 25,000 km
                          At the time I couldnt shift fast because of a combination of my clutch master cylinder being **** and didnt have my engine torque damper installed. The transmission would grind from 3rd to 4th so I would shift smooth. Yes you can hear the waste gate open later due to the screamer pipe. My car drives great for the budget build it was and it's been fun for the past two years and hopefully 2012 and possibly another year. The plan is to build an rb30/26 in the future and this set up is utilizing what I have and what I can afford.
                          That being said there are some weaknesses to my set up which could improve spool. Basic good quality top mount manifold, equal length and smoother collector should also help. My car has variable valve timing which isn't compatible with my power fc so of the three settings, low, mid, and high, the valves are set on high. Further, the piping on the cold side of my intercooler is bigger to match the 90mm throttle body. My greddy copy intake manifold doesn't have a smooth or velocity stack type inlet to each cylinder. As you can see the weaknesses in my set up are due to lack of brand name quality parts. You truly get what you pay for. And 200 rpm may not seem like much but when you want the car to go NOW it makes the difference.
                          That being said, I do have fun with my 492 rwhp rb25 bone stock motor as a daily driver for 9 months of the year.
                          It's a testament to good tuning and what these motors can do.
                          It takes trial and error to understand these cars. The future build will be a response monster 700rwhp daily.
                          R33 GTST RB25DET series 1
                            hey bro, that's awesome! quick question, roughly how much did you spend on that build?
                            and if you could tell me exactly which products u were using for the manifold and plenum throttle bodies,, where did you get all that stuff? ebay?
