for rb20det;
so ive been trying to set my idle speed for the longest time. its a mix between it not being set right and a rough idle.
i set the signal voltage on the tps to 0.5 with ignition on(engine not running)
with the IACV electrical unplugged i can adjust the the screw to get my desired idle speed(aiming for 1000rpm for now) and it has decent throttle response. then when i plug the IACV electrical back in the engine spikes up to 2000rpm and im pretty sure this isnt supposed to happen. the rpm adjustment screw on the ecu does absolutely nothing, and even if it did its only for a 250rpm adjustment(according to the fsm book)
could the IACV be broken itself?? i had taken it apart and cleaned it with carb cleaner during the build.
