Hey guys , going to be buying Walbro fuel pump part num:gss342 . My question is do I need a vehicle specific install kit? Or can I just use a universal install kit ? Also should I run Walbro ??
Installing Walbro fuel pump
ya but I didn't know if people recommended other pumps other than walbro, I can also get deatschwerks etc. So ok, I'll buy a Walbro 225lph and a 240sx install kit. 255lph is good for how much HP? want to make around 350whp
I've heard the Stock FPR is good for like 400-500hp is this true? I'm running the following
also running 750cc Deatschwerks injectors
Part #: wal gss342
Manufacturer: Walbro
Description: Walbro 255lph High Pressure Fuel Pump *WARNING - GSS342*
Part #: wal 400-766
Description: Walbro fuel pump kit for 89-98 240SXLast edited by Michael1992; 03-01-2012, 10:37 PM.
Yes the info you have is correct, I was over 500whp with the same pump (still running it) and the stock FPR. Iv upgraded fuel lines ,rail and FPR last year when I tuned with meth.
*Im running 870cc Deatschwerks injectors"LAG is the time the guy beside you thought he won"
I deal with walbro directly, no knockoffs here.. And common sense because of his dp ?? Well many people run front end conversionsOriginally posted by M13 View Postwalbro is fine, just don't get knock-off then blame walbro for your shitty pump.
evilgtr has an RB26, but hey, that's just my common sense.
