what do you guys think the problem is?,
since i got a different cas the dieing problem stopped, now its just that it wont start sometimes for the past few days, usually after night (leaving it for a few hrs or more) and now it just wont start period for the past 2 days
ive been doing the testing cas trick (spinning it by hand with the throttle on and key on) and there is fuel and spark sometimes, there is just fuel sometimes, and there is nothiing sometimes, lol funn eh?
after it starts giving fuel and spark i quickly put the cas back and it will start and run fine untill next time it tries the funny **** again...
i rewired power and ground to the cas (and anything else that uses the same power/ground wires since i just tapped into them) didnt help, i ohmed out the cas signal wires to the ecu and they came up fine, ive cleaned almost every valve/sensor in the past few weeks because of other random problems that are now fixed/gone away
last time it was running i had my consult cable connected and all the sensors seemed to be reading properly, (temp, throttle pos, aac valve, rpm, injector duty, O2, MAF)
thx for the help guys, this is driving me insane
