Help. Smoking
  • Help. Smoking
    Car is a 90 Gtst 194xxx Kms. It's been driven hard 7 turbos. I have an issue that arose today. Noticed it smoking a lot at idle. So went and smelled as just smells like burning. I'm an apprentice so I've learnt what oil or coolant smell like and it's not sweet not blue either more grey white. I know I'm rich at idle but this is different. Has a ws0448 turbo witch was new a year ago. Has 10 xxx Kms on it. Rev up goes away then wait a few seconds and starts up again.
    1990 gtr .... in need of axle and some tlc
    1990 gtst 4 door, slammed, 2 toned, and fun.
    Maybe coolant is leaking when you give it gas and cooking on the turbo or manifold? Your lines are leaking, my guess is your WS racing or what ever ebay turbo you have came with crappy lines aswell.
    Sent from my BlackBerry 9700 using Tapatalk
    92 Gtst/Silver bullet
      Do you have a bunch of bubbles/pressure in your coolant reservoir? How old is your rad cap?
      Regards,
      Ken.
        I Pit a new rad in july
          Sounds like head gasket issues. Check your rad overflow tank and check the dipstick and bottom of radiator cap to see if their is a mix of oil and antifreeze. It will look like soft mud (pic below) Even if it doesnt look as bad, i'd take off the head still and check for head gasket failure. Oh and this will mean significant damage.
          Double track drift, yo.
          (o▫o sκylιnε o▫o)
            Rad cap and over flow are clean coolant still green. Oil has no foa
            Ing or sign of contamination
              Hmmm if it just blows white smoke at start up it could be the PCV, black smoke could mean rings
              Regards,
              Ken.
                clean your maf/ replace will probably fix it
                TO GRIP OR NOT TO GRIP.... THAT IS THE QUESTION
                  Journal bearing let go in the turbo. Pulled the feed line after sitting all Nigjt and it was still full and the return was dry. Then you hear the bearing inside grinding. Turbos almost all part and parts ready to be prdered
