Check coilpacks.
I ran NGK PFR6A-11 (11 = 1.1mm which is stock gap and NGK PFR5A-11 is stock sparkplug for RB20DET) regapped to 0.8mm with hybrid factory turbo (bigger than factory turbo) at 12psi (270hp at engine) and went as lean as 13:5.1 when on boost (lean = higher cylinder temps, so PFR6A worked with heatrange, but was suggested to use PFR7A).
NGK recommend to change heat range every 75-100hp or when engine runs leaner or richer.
