I'd like to start with an apology if this post has already been done before, but I searched all my keywords twice and both times came back with nothing. Anyway, I'm running a basicly stock 95 gtst. I've been having problems with shifting from 3rd to 4th gear at high rpm. I'm putting my foot to the floor on the clutch, but it still grinds unless I wait for the rpm to drop then slide the gear shift slowly back into 4th. I'm sitting at around 92000km and I'm the 3rd owner. From the fairly detailed amount of paper work I have on the car it doesn't look like the clutch has ever been changed. I'm wondering if it's just time to swap it out. Correct me if I'm wrong but could it be that it is worn to the point where it can't take the amount of torque at that rpm? Thanks for all the help!
Grinding from third to fourth gear at higher rpm.
It's the mind that makes the man, not the color of his collar!
95 GTS-T RB25 R33
Apexi power intake, stage 2 clutch kit, HKS exhaust, Mishimoto rad, DBS 4000xs rotors, yellowstuff pads, HEL stainless lines.Tags: None
Mine does the same thing. Installed an engine dampened, didn't help
I'm putting syncromesh fluid this year, lots of people have had great success.
If the problem doesn't go away I'm gonna do the transmission bushings.
I can only imagine the stress they are under at high rpm and the clutch releasing causing it to moveR33 GTST RB25DET series 1
I've ordered an engine damper, and a new clutch kit. I'm going to change all the fluids too. I hope it all helps. I don't really like the drive it till it breaks thing... Usually costs more that way! Lol! I like the preventative maintainance approach better. This things my baby, and I want it to last so I can hand it down to my son. Preferably with a lot more mods done!It's the mind that makes the man, not the color of his collar!
95 GTS-T RB25 R33
To true! Thanks for the feed back! Much appreciated!It's the mind that makes the man, not the color of his collar!
95 GTS-T RB25 R33
Is it possible your clutch slave is leaking???
Can R33 clutch pedal arm be adjusted like R32s??? Changing how far the piston is inside the Master.
Syncromax and Shockproof are the Fluid of choice. I run Syncromax.Last edited by beacher1B0; 06-09-2012, 11:49 AM.
How do I adjust that? I'd like to give it a shot!Originally posted by beacher1B0 View PostIs it possible your clutch slave is leaking???
Syncromax and Shockproof are the Fluid of choice. I run Syncromax.It's the mind that makes the man, not the color of his collar!
95 GTS-T RB25 R33
If run a quick shifter it can cause synchro problems with RB25DET transmission.
Nismo solid shifter doesn't have this problem and they explain how the quick shifters cause problems with synchro's -
I'm not running a quick shifter that I know of, one of the previous owners may have thrown one in though. Anyone know if that redline stuff is any good? And where i can get it? I did a couple searches, and couldn't find anything on it except in other forums. Some people where saying it eats syncros. Others where saying mix it with regular fluid. Help!It's the mind that makes the man, not the color of his collar!
95 GTS-T RB25 R33
My GTR had 4-5 shift grind, I put Redline Shockproof Heavy in and no more grind, had it in there for like three years no issues . ( I don't drive it that much though but did a track day with it last year) you have nothing to lose,it's a no brainer pull trans or try changing fluid. Some say it eats sycros slowly I think cause of sulphur content but who cares if they are already wearing out.
Through in redline! Worked like a charm! Thanks everyone!It's the mind that makes the man, not the color of his collar!
95 GTS-T RB25 R33
