Anyone had this fail on their GTS-T? What were the symptoms?
Symptoms of Bad Cam Angle Sensor?
follow my thread to see if this is your problem. When my CAS failed, i would lose power while on the throttle for about 1-2 sec.
Godzilla - 哥斯拉 - ゴジラ - گودزیلا - Годзилла - גודזילה
I have had 2x CAS fail and was due to the bearings inside CAS (from memory they are NTN bearings with part number on them).
Symptoms are 1-2 degrees decrease in ignition timing (engine feels less responsive), hard starting when engine is cold and hot, CAS error code on ECU. If you leave it for too long the bearings inside CAS can make engine stall.RESPONSE MONSTER
ohh well... mine... simply died on the highway.. you know like when paul walker got hit by an electric gun and hes fake r34 went from vroummm to zoouuummmmmm.. well same thing happened to mine.. I almost had a major accident because i was going 30kmh in a 100kmh highway exit ( 1 lane only couldn't move to the side).
Very fun.. so I bought a new one in a heartbeat.Need detailing done to your car? I'm open to travel to detail your car :
