OK, so I have been trying to get this rb25 neo running for a couple of weeks now. I've done all the wiring myself and I'm about 98% sure its all done properly.
i have fuel pressure, pump is wired to 12v constant through relay.(actually spikes way up to about 100psi)
new tomei fuel pressure regulator.
listened to the injectors with long screwdriver while turning the CAS and they're all clicking.
pulled the coil-packs out, and with the spark plugs in them i turned the CAS. there's spark.
I re-checked the cam timing, and its bang on.
ive tried to start with maf unplugged. nothing.
tried to start with ICV unplugged. nothing.
installed fresh spark plugs after them getting fouled
so im running out of ideas.. the engine cranks from the starter turning, but it doesnt even try to start. any ideas from anyone of what i could try next??
the rb25 is from a r34 GTT.
One thing i noticed was the TPS has 6 wires going to it. in two sets of 3, one set is black red and white which is connected. and the other set of 3 is brown yellow and green which isn't connected to anything and aprears to blacked of from the factory.(looks like and oem blanking plug)
