hey
got my car back finally and been working to get it back to someone decent condition
issue is car takes bit of turning over to finally start... its like there isnt any fuel getting to it, then all of a sudden it will fire up
second... once its started it will idel at 1500ish rpm, then go down to 800ish and then just die out... wont rev past 3000rpm, just cuts out
that i have done thus far today, installed new plugs, oil change, removed IC piping to do plug change, had to remove maf due to new air filter install...
thinking its the maf... any thoughts on if that is the case or anything else you think it might be...
it was running completely fine (other then the rough starting) before i did the above... so it could be sparks? could it be maf?
thanks in advance guys!
