RB25 series 1 or 2?
  • RB25 series 1 or 2?
    Was wondering what series a 1994 skyline with a RB25 is? series 1 or 2? How can I know?
    Thanks!
    Do you have a metal box about the size of a pack of cards on top of the sixth cylinder coilpack cover? If so it is a s1
      Hey! thank you very much!
        The coilpacks in s1 have 2 wires each into them and have 4 bolt holes for mounting, s2 have 3 wires each and have only 3 bolt holes. -and no igniter as mentioned above
        They switched from s1 to s2 part way through 1995
        01 Chevrolet Maliboom-boom (winter BEATER)
        93, 94, 96 Toyota Supras
        95 R33 GTS-T
        04 R44 Raven1 helicopter
          On series 2 R33 RB25DET they moved the ignitors from ignition module on back of engine to inside each coilpack. They did this, so can shut each coilpack off individually via ECU (ECU programming, etc was changed to suit). Same setup was used on R34 NEO RB25DET. The igniton module is still there, but smaller.
          Series 1 R33 RB25DET runs same setup as RB20, RB26 (have to remove coilpack cover, etc, unplug each coilpack while engine is running and coilpack that doesn't affect engine = failed or check them on bench via multimeter or coilpack testing machine).
