Hey guys, so im reaching out because im really frustrated with my skyline and need a little advice in which direction to go if you have any.. So before the car was stored i would idle normal when cold and then sounded like it had a slight miss or was hesitation when warm, it was drivable for a bit and then started bucking and serging.. Also stalling at lights, after a couple days of this i decided it wasen't worth driving so i began work on it.
I replaced the tps because the other one was giving bad readings even after adjustment.. which made no difference.
Upgraded to new spitfire coilpacks and got a new igniter, as well as cleaned the MAF, inspected the plugs which were fine. ANyhow the car has a really rough time starting up..and once warm just stalls out. Don't really know what else it could be, maybe CAS or IACV? if thats the case then i don't know how to test them out. Anything would be helpful because if i can't fix this soon im going to take insurance off. Thanks!
