injectors for HCR32 need help what to choose
    There is a calculator to work out injector size -
      Target Crank HP kW PS # of Injectors Induction Type Turbocharged Supercharged Naturally Aspirated Fuel Type Gasoline Ethanol Methanol Ethanol Blend E98 E85 B.S.F.C. Value (optional) Max Duty Cycle (%) Injector Flow Needed 0.00 cc/min Reset Target Crank HP Induction Type Naturally Aspirated Turbocharged Supercharged F
    Stick to 80% duty for reliability on racetrack (to prevent overheating of injectors). If stick to 80% duty, 383cc is about right for 350hp engine.
    Fuelpump calculator -
    Higher fuelpressure is needed to match boost level. 1psi of rail pressure = 1psi of boost pressure (1:1). Factory engine is around 7psi stock, and stock FPR raises fuel pressure 7.1psi (up from 35.5psi at idle). Some aftermarket FPR's are rated to 100psi.
    If add a bigger lph aftermarket fuelpump, the small orifice on stock FPR makes fuelpressure rise into low 40's, up from 35.5psi.
      i dont know how much this gets asked but its quite alot, search older threads skym and i have given out injector info on quite a few occasions it would have given you all the info you needed
      TO GRIP OR NOT TO GRIP.... THAT IS THE QUESTION
        Buy my set of http://www.deatschwerks.com/products...-0440-6-detail
        Brand new in box. 200 + shipping.
        Rusty 240sx 1JZ project.
          329.00*
            or!!!! you can get http://www.deatschwerks.com/products...989-94-rb20det
            these. i have 650cc's and iam very happy with them. iam also running a nistune so i can get whatever injector size i need. tuning yourself isn't that difficult.
              I have my gtr injectors for sale.
              Sent from my Nexus 4 using Tapatalk HD
              Currently rollin' in a 1997 Nissan 240sx こうき
