so the weirdest thing happend to me this past saturday night.. fired up the rb 25 and drove a distance to kansas city from my garage for ths first time since i finished my swap. you know to get the bugs out and what not. then this happend.
Heres some back cliffs. when i replaced the old oil pan, and while cleaning the oil pickup there were 3 small pieces of aluminum shavings on the oil pickup. i thought nothing of this, but this may have played a part in what to come.
i finished my swap started up the engine. ran good no knocks or lifter tick. mind you i got a brand new n1 oil pump. so thankfully i had my harness done the right way so my oil pressure sender unit/dash oil light worked. never had any oiling problems untill this night.
i used dino-oil and a cheapo fram filter to just get a feel for the engine and planned on using synthetic later on(that didn't work out).
so iam driving around. working on my tune using nistune. i was copying and mimicing my stock fuel map that i uploaded through consult. i got a happy medium of 14-15 afr idle and about 15-16afr crusing mixture.
there are sensors on nistune/consult screen and the vtc window would blink but wouldn't go into red. (the fuel temp sensor was apparently busted). but other than that there weren't any notacable problems.
i didn't really get on it much as i was still breaking up above 15psi(i needed a pro tune). I wasn't bouncing off the rev limiter, just a little throttle here and there.
so them my dash oil light came on. great, so i went to walmart and got some more oil. on my way there when i was in throttle the light would go off, and flicker but i still got 2qt's to be safe.
put the 1st one in. and the light went off. then later on that night after starting the car. i had a damn lifter tick!!! WTF!!!
IT got louder as i went. so i added the other qt of oil, it sounded like it was getting better. then on the highway i hear a loud "CLANK"!! i get like maybe 5 more engine revs and like a couple more hundred feet to roll and thats sll she wrote. engine will crank but won't tuen over. sounds like there something stopping the rotation process!!!
and on top of that i see oil leaking out the bottom of the engine so my initial suspect was a bad oil pump. seeing as ive had a bad run-in prior with the n1 oil pump.
but a few days later and after a teardown and inspection heres what i found!!!
looks like the timing teeth were skipping a beat!!!
went to pull off the timing gear and violia!!!
