my guess: thoes shavings you found when you dropped the pan before all this, were the cause, could have been previous damage on head - cam surface. could have blocked the head feed on that side and caused it to seize, the heavy valve tick would have been the warning signs that the head didn't have sufficient oil.
rb25 vtc-cam failure!!
Originally posted by amnash View Postdid you have an oil restrictor installed? making me hesitant to buying one and fitting to my rb20 block.. normally the head is over oiled on the RB's... weird
I can answer this for you.
If you look at the RB engine blocks you will see 2 larger oil return passages at the rear of the cylinder 6.
Under high rpm oil is pumped faster to the top end and only gravity can return it to the pan.
With acceleration oil will accumulate at the rear mostly.
However also at high boost levels blow-by increases and also uses the oil return passages to escape the crankcase.
This causes the oil in the head to not fall through and pools in rear of the head.
That's why the rear head drain came to light adding an additional passage.
Hope that explains it.Last edited by speedfreak; 04-12-2013, 09:52 PM.Favorites
lucky_cefiroyou\'re not listeningstop saying "yall"... i'm picturing you with a mullet.
mullet+skyline=*shiver* i dont even want to think about itOriginally posted by specialeditionHe ended up popping a tired and he failed at life.
It's not a head drain as such (does act as a head drain as well), it's designed to help equalise pressure in sump, head, so oil returns through stock oil drains. With high boost levels (I think was up to 1.7 bar) the blowby going past rings pressurises the sump, hence the pressure blocks the stock oil drains (makes it harder for oil to return to sump). Equalising the pressure in head, sump (removes the pressure buildup in sump, as pressure goes to head and out the cam cover breathers) and allows oil to return to sump via the oil drains.
This is a basic diagram, explanation of what happens with too much oil going to head (scroll to bottom in link below) -
To solve it properly (especially when running higher boost levels), run a dry sump setup (not many can afford a dry sump setup hence the above restrictor mod was created for mild tuned race engines).Last edited by Skym; 04-13-2013, 05:53 AM.RESPONSE MONSTER
Iam hoping to pull the engine today and do some more disassembly!
Originally posted by supersayianjim View Postthey seem like a good company. but i don't need a whole motorset, just a complete longblock so iam stuck on that one.
http://www.rawbrokerage.com/nissan-r...gine-motorset/Last edited by DatsunZ31; 04-13-2013, 10:32 AM.
Originally posted by supersayianjim View PostThe only oil restrictor I have is the stock) oil turbo feed bolt(yes the same thread pitch as holsets). Other than that no limits on oil.
Holsets need -4 an oil feed, no restrictor.Built R32 GTR, BW S362, 682awhp @ 28psi
ive used the stock t28 feed line for years on my hx30 and no problem, iam running a hx35 and it's the same thread pitch. iam not starving the turbo, if anything it's still getting too much oil.
so i put a deposit down for another motorset. iam going to part out and build thsi bottom end of the one i got. so look for the f/s thread comming up!!
i can take pre-bids now for the coilpacks/harness etc stuff.Last edited by supersayianjim; 04-16-2013, 06:24 PM.
heres the next(and hopefully last) motorset iam getting. yes i know it's awd but i have a oil pan etc.Last edited by supersayianjim; 04-19-2013, 10:07 PM.
nice looks good man!! good to see you didn't let the motor failure get you down
but im going to have to correct you on that one. if the line your using is restricted that's a no no for a journal bearing turbo, such as every holset out there.
The rb20 and rb25 both, ball bearing, have the restrictor right before the banjo bolt that threads into the turbo, also the feed through the banjo bolt is just as small.
picture i just took of my oem he341 size and the RB feed size. the difference is huge
not trying to call you out, just not good to have false information floating around the netBuilt R32 GTR, BW S362, 682awhp @ 28psi
Originally posted by nick-nismo View Postnice looks good man!! good to see you didn't let the motor failure get you down
yep, thats the feed line ive been using. along with the stock rb feed bolt.
Have no idea what Holset turbo's have with CHRA, but R32 GTR (from memory is a 270 degree thrust bearing), R33 GTR stock turbo's are non ball bearing, R34 GTR is ball bearing. R32 GTS-T, R33 25T, R34 GTT stock turbo's are ball bearing.
Hybrid RB20 turbo is non ball bearing, as they tell you to drill the oil feed out in the instructions that are with turbo from turbo rebuilder.
Only stock turbo on GTS RB engine that is non ball bearing is installed on RB20DET in the Cefiro.RESPONSE MONSTER
