Hey guys, so I just bought some tein flex coilovers and I'm having some trouble with the installation, I can't seem to get the front pair on because they do not have the lengh to be bolted up even when they are on highest setting...not sure but if anyone has a guide or some tips it would be greatly appreciated, thanks
Coilover installation
Put a jack under the control arm, bolt on your shocks with the bottom bolt and slowly raise your control arm. Make sure you don't rub the threads on the holes & double check all torque specs. The shocks require very low torque settings compared to any other suspension component.sigpic
4 door love.
Last edited by DarkCaporaL; 04-17-2013, 07:25 AM.R32 GTR FULL SERVICE MANUAL DOWNLOAD:
Be aware that new springs take a while to settle (could be a week or two of driving), so ride height will drop roughly 10mm or so (take that into account when adjusting ride height). Because of this drop in ride height, alignment needs to be redone.
Also monoque chassis are usually not square, so ride height would be different on each wheel (let alignment specialist adjust ride height) to get car to sit evenly. Should corner weight the car.
Also ride height can affect understeer, oversteer, etc. What ride height works on one car might not work on another.Last edited by Skym; 04-17-2013, 02:58 PM.RESPONSE MONSTER
