Hey guys,
So i just got my car swapped from a rb20 to an 25 s2. So the first day back my problems started!
I was driving back to my garage where i work from the swapshop and the car started to over heat. So i get to my shop in the nick of time pop the hood and what do i find! Black Coolant!
So after i finished work i continuously flushed my cooling system the the following three hours! The Sh*t that came out of my motor was terrifying! Basically looked like my coolant and oil were mixing! Only problem is my oil is super fresh and golden! So i know my coolant isnt mixing with my oil via head gasket or atleast i hope so.
So after 3 hours of flushing i decided to wrap it up with hopes the over heating would stop. i was wrong had to pull over nearing my house 10 mins later as temps spiked.
Anyway so i got the car back to my swap shop that did the swap and they said could be a possible oil leak within the oil cooler and coolant lines. So they replaced it and same problem!
Im a little lost for ideas as i couldnt figure it out and neither could the mechanic at the other shop. Im assuming if i remove the thermostat and flush the block it might solve my issue with the current crap coming out of my engine perhaps even drain the block completely.
Has anyone had issues like this before, or an idead on how to fix this? any help wouldk be appreciated greatly.
Thanks
Thanks
