so i blew the stock turbo on my s1 rb25 and I'm thinking of doing the garrett gt2871r a couple things I'm unsure of are how much boost it will hold, how much hp its good for and how difficult it will be to install... is it gonna be anything close to a stock bolt on ? what a/r would be better .86 or .64? also i have a mines stage 1 ecu , fmic, exhaust and some other little parts..
rb25det gt2871r .. blew stock turbo :(
Need a aftermarket retuneable ECU (or modified 300ZX ECU, etc if on a lower budget), good gas (at least 94), as are working with a higher compression engine where ECU tune, gas it runs on matters the most if want engine to last. Also fuel system to match.
Ford T3 5 bolt housing, ATP swing gate assembly, etc from here -
HKS GTRS should be bolt on and mentions A/R of exhaust housing, etc -
Use injector calculator to get a rough idea of what cc injector you need for the hp level you want at engine -
Target Crank HP kW PS # of Injectors Induction Type Turbocharged Supercharged Naturally Aspirated Fuel Type Gasoline Ethanol Methanol Ethanol Blend E98 E85 B.S.F.C. Value (optional) Max Duty Cycle (%) Injector Flow Needed 0.00 cc/min Reset Target Crank HP Induction Type Naturally Aspirated Turbocharged Supercharged F
Fuel pump calculator -
Need custom oil lines (with correct size oil restrictor for ballbearing or non ballbearing core and size, etc is mentioned on ATP website), coolant feed, etc (ATP sell those).
Stock ECU is retuneable, but noone that I know of outside Japan has the equipment to retune it with the 184pin chip, etc. Most use 300ZX (with Nistune that makes it retuneable) that's modified internally to plug into stock loom with Z32 MAF, Z32 plug to suit.RESPONSE MONSTER
If want a bolt on solution (stock oil feed, etc), hybrid RB25DET turbo is good for over 400hp at engine (1bar) with Link ECU + MAC boost control solenoid, IAT sensor, hybrid brand FMIC, 3" exhaust into 3.5" exhaust, injectors, fuel pump. But you need to drill out stock oil feed, as it's designed for stock turbo with ballbearing CHRA and hybrid turbo is non ballbearing. Also machine out stock wastegate hole on back of turbo, as it boost spikes if you don't. Another mod would be bigger A/R VG30DET exhaust housing to prevent compressor wheel hitting surge line (if drive accordingly it shouldn't happen with stock RB25DET A/R exhaust housing).
Cherry turbo makes hybrid turbo's -
